12-11-2018 03:47 AM
Does the microphone even has an adjustable sound level? It might just sample, and then leave it to the software to adjust the signal. I'm not sure if there is a hardware gain...
If you can do it in Windows, you'll be probably able to do it through an API.
12-11-2018 01:28 PM
@bseguin wrote:
Unfortunately, there is no native way in LabVIEW to set the volume of a microphone.
I suggest you to read the documentation of the audio device that you have. They might have a .dll to do. If not, you will need a wrapper from .net to LabVIEW.
Benoit
Is there any way to access an audio device in LabView using .NET without 3rd party software?
Benoit
Benoit
What Assembly and Object do I need to use?
12-11-2018 07:03 PM
I know that it should be possible, but I never did that myself.
I prefer use DAQ since the frequency and precision are much better.
Benoit
12-12-2018 06:35 AM
you can try this to set microphone level.
/Peter
12-12-2018 08:31 AM
@pets wrote:
Dupe post
Then please post the link(s) to the duplicate post...
12-12-2018 08:37 AM
hi i posted the same thing twice so i deleted the last one and labeld it dupe.
should i name it something else?
or can i delet it?
12-12-2018 09:03 AM - edited 12-12-2018 09:05 AM
Usually when a duplicate post is reported, it refers to a new thread posted twice.
If you created a duplicate thread, you can get it removed by reporting it to a moderator (under options).
I did not know you could delete it yourself, but if so that would work too.
I see only one post, so I guess the "dupe post" was redundant and confusing. But never mind, no harm done.
