12-12-2018 03:55 AM - edited 12-12-2018 03:55 AM
HI.
I have an array of data from ADC (sinusoidal signal was applied to the input). Is it possible to calculate offset and gain error from this array? Thanks.
12-12-2018 04:59 AM
Yes, that is possible. Providing you have the original input level of course, or you'll only get an amplitude, not a gain.
Details will vary depending on the exact requirements.
I'd use a (PtByPt) FFT. That would give you a DC (at 0 Hz) and a peak at the sinus frequency representing the gain. There are probably specialized tone analysis VIs as well...
12-12-2018 05:05 AM
I don't think that FFT is need to use. Most likely should be used mathematics.
12-12-2018 08:17 AM
Isn't FFT mathematics?
It's not about 'need' to use, for me it would be the easiest and most intuitive way to make it.
12-12-2018 08:41 AM
So how from FFT get this parameters if all data in FFT is dB?
12-12-2018 09:06 AM
FFT PtByPt.vi doesn't return dBs...
