labview based
Dear Sir,
              in my application i m using event structure in while loop . and outside event structure   i am using get date and time and random generator but when i run it it execute evet strucure but it does not execute the other thing outside the event structu re
Message 1 of 12
(5,183 Views)
please show the code of what you are doing.
Freelance_LV
TestAutomation Consultant
Message 2 of 12
(5,181 Views)
i am very new to labview i have tried it from last 2 days . so i have desined the front panel and i am now using the object of front panel
Message 3 of 12
(5,171 Views)
Message 4 of 12
(5,163 Views)
I would recomend having a look at this: https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
From having a look at your code, I would use an architecture simmilar to that in Figure 2 of the above link.
Message 5 of 12
(5,157 Views)
This VI is broken so it won't run anyway. You are trying to wire a cluster to an array in the while loop with the Get Date/Time.
Message 6 of 12
(5,154 Views)
your sub vis are being loaded from different paths. some are loaded from My Documents folder and some are loaded from Temporary files folder.
have all your sub vis in one folder, along with the main vi. then post the zipped folder.
also, how did you conclude that the code outside event structure is not running? you have a broken arrow!
Freelance_LV
Message 7 of 12
(5,153 Views)
Event has an timeout terminal, Which is not connected to anything. So the GUI is waiting for user commands for indefinite time.
Connect it to any value lets say 100ms and see if the problem persists.
Labview user
Message 8 of 12
(5,141 Views)
Accepted by preet_singh
beacuse it runs only once it doesnt update the time in every second . it only get the time once and if i put one more while loop inside while loop then its find ok but other part doesnt work well
Message 9 of 12
(5,140 Views)
I am also in CAT
EXT-2554
Probably it will be better if We can discuss.
Labview user
Message 10 of 12
(5,134 Views)
