create subVI with while loop
i have a big program which is in a while structure and when i try to make a subVI, i have a message which tell me that my selection contain a front pannel which is in a while loop. How can i do to make a subVI?
Thanks a lot
Message 1 of 8
(5,187 Views)
If you make it into a sub-VI, how are you gonna press that stop button?
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(5,175 Views)
Hi macarel,
just proceed 🙂
You should ask yourself: Which front panel control? Is it intended to be used in the subVI?
Message 3 of 8
(5,174 Views)
It wasn't planed to make subvi's.
My program is initialy a main Vi with buttons Each Button launch another specific VI which make a specific measurement.
It works very well. But when i make an executable, it doesn't works.
So i try now to make only one VI with all the specific VI inside but it doesn't works too. The front panel of the specific VI never appears.
I searched in the forum and all the person who had this problem and solved it used subVI.
So i try this solution... which doesn't works too.
any suggestions?
Message 4 of 8
(5,159 Views)
Hi Macarel,
Because you didn't check the VI properties, especially the window properties?
Message 5 of 8
(5,148 Views)
Do you mean "show front panel when called"?
It's checked but no enhancement.
Message 6 of 8
(5,142 Views)
Hi Macarel,
this would be the right time to show main and sub VI as well as project/appbuilder settings...
Message 7 of 8
(5,132 Views)
Hi, If you want to show multiple subVIs, then you have check there windows appearances. Other then that if you want to control them from your main VI. then you have to place your subVIs in separate while loop inside your main VI. this will cause main vi to constantly updates control in SubVI. Hope this helps your problem.
Labview user
Message 8 of 8
(5,105 Views)
