indicator not showing array
I am currently developing a machine at work using LabView 2011. Basically it is a gas cycling machine. I sense the output pressure and cycle the valve state. But I have one problem, at the beginning I'm initializing an array of 10 elements with '1' in each one of the elements. After that, the array goes to a producer/consumer code. The problem I have is that I put an indicator to the array before the loop, and when I run the VI the indicator shows and empty and grayed array (like if the indicator was never used), I also put a probe to the wire and there it does shows the array. Also if I connect the indicator inside the loop, the indicator shows the array. So why the indicator just after creating the array isn't showing? In the image below there is a part of the code, array 1 does not shows nothing in the indicator, while array 2 does shows it.
Thank you.
Message 1 of 16
(5,536 Views)
This is really unusual behavior.  two possibilities.
1 you actually have two indicators named array 1 and you are looking at the wrong array.  (run the vi anaizer and see if you have terminal with the same name)
2 there is an insane object somewhere.  (recreate your vi)
{edit}
Whoops - looking again - your bd shows "array 1" and the fp shows "Array 1"  you are looking at the wrong indicator!
"Should be" isn't "Is" -Jay
Message 2 of 16
(5,535 Views)
Good catch Jeff. Smiley Wink
Message 3 of 16
(5,527 Views)
Thanks for answering Jeff, but that array 1 is just the caption, Array 1 is the name for both.
+++1 you actually have two indicators named array 1 and you are looking at the wrong array.  (run the vi anaizer and see if you have terminal with the same name)
I already checked this and it is just the indicator and they have the same name.
+++2 there is an insane object somewhere.  (recreate your vi)
What do you mean with "insane object?"
Thanks Smiley Happy
Message 4 of 16
(5,520 Views)
@rugebiker wrote:.
Thanks Smiley Happy
its a very rare condition but it does happen- usually on vis that have become very large and highly edited.  A bit flipped somewhere and somethig bad happened to corrupt the code.   Darren pointed out a bit about them (and a few links to special methods that sometimes find them) here
Message 5 of 16
(5,513 Views)
As a shot in the dark, I have seen some funny behavior when LV tries to fold code, and that initialize array function looks like a prime candidate for folding.  You can try a couple of things, change one of the constants wired to the Initialize Array to a control, or try putting an Always Copy primitive in between the Initialize Array and your first indicator (that is often a good band-aid for these head scratchers).
Message 6 of 16
(5,511 Views)
Nice thought.  the init will be folded.  If the allawys copy works.  Please strip down the code or zip it with all of its sub-vis so we canexplore the bug in the compiler you just found.
Message 7 of 16
(5,507 Views)
 I tried both solutions, but none of them worked =/
I also found something interesting: if I add a breakpoint to the wire before between the array and the first array indicator, when I run the program the indicator shows everything in 1, like it is suppose to be, but if I unpause the VI, then the indicator becomes gray and with 0 again. =/
Message 8 of 16
(5,494 Views)
Any locals, or other use of that indicator?  I say post the simplest version of the code which shows the problem.
Message 9 of 16
(5,491 Views)
I'm not using locals or other use of that indicator. It just used there. I cannot upload the code because it is forbidden here where I work, sorry.
Message 10 of 16
(5,488 Views)
