i want use google map api in VI . i tried so mutch to do it.i used google earth plugin and google static map but i need only google map api .
Hi Garousi & Richard,
As promised, attached is a simplified version of DYNAMIC google map in Labview. Just start the application, click the "Load" to load the map and "Add Marker" to put a marker on the map. Along the way, you might want to take note how easily we could call JScript functions from LV.
The attached is only a very simplifed and limited program, which is just for giving an idea how we could accomplish this in LV. There are a lot more functions supported: moveMarker, moveCenter, changeMapBounds, drawPolyline, etc. that due to the intellectual policy of my company, I could not disclose everything. But once you got an idea how initialize() and addMarker() in my program work, the rest should be straight forward. You can find all supported Google Map Api functions following this link: http://code.google.com/apis/maps/documentation/javascript/tutorial.html
 Some important notes that you might want to take in consideration:
1. Currently we could not pass any data back from JScript to LV,
2. LV does not know when the called JScript function ends. For ex, addMarker() function is called, but due to slow internet connection, it takes some time to finish. LV does not wait until it finishes, and if you call the drawPolyline() while the first one is not done yet, drawPolyline() will override addMarker(). My workaround solution for now is putting some delay between each JScript functions' calls, and allow user to change this time interval during run-time.
3. Google Map for commercial use is not free, and it's kind of expensive.
So guys, please do give out any comment if you have any.
@Garousi: I really appreciate if you could share your code as well. So we could seek a best solution for all of us:D
Thanks so much !
Cheers,
Daniel
Message 11 of 134
(8,863 Views)
Hi Daniel
please check this example , I think we don't have any limited here
I can't upload my zip file . I don't know why  Smiley Sad
my sorce file is read Smiley Wink please help me to upload file .
M.Garousi
Message 12 of 134
(8,854 Views)
OK , you can download file in here : GMap.zip
M.Garousi
Message 13 of 134
(8,838 Views)
Hi Garousi,
The picture looks great, I haven't taken a look at the code yet since Im not allowed to download in my company.
Btw, r u using the one that you sent me earlier, or google map JScript? And can u elaborate on the point "not limited"? I'm really concerned about that.
Thank you !
Cheers,
Daniel
Message 14 of 134
(8,792 Views)
hi  i need  crate  a key  API  for google  but i dont know... i need  create a   server http ??
or how to create ?
thanxs and sry for my english jj
Message 15 of 134
(8,763 Views)
Hi Daniel
in this picture I use GMap.Net.WindowsForm.Dll , I checked  your source code . when I create many marker and update markers some of that markers can not be updated and give error .
please check my source code and I appreciate that if you send me solution .
M.Garousi
Message 16 of 134
(8,750 Views)
Hi
Please tell me , what's your means . you want use API key in web browser or use GMap.Net.WindowsForm.dll or use static map in picture control , ...
M.Garousi
Message 17 of 134
(8,747 Views)
HEY MF  I NEED YOU HELP  IN THE FIRST EXAMPLE  I NEED CREATE A  WEB SERVER (HTTP) ??  FOR  KEY  API  GOOGLE??
I DONT KNOW
Message 18 of 134
(8,728 Views)
Hi
if you use my sorce code , you don't need web server or API key , you just use 2 dll that I put in this address : http://www.4shared.com/folder/uK6kv_HZ/_online.html
please check it . if you have any error please share here picture of error and put here picture of project explorer .
same as :
M.Garousi
Message 19 of 134
(8,681 Views)
Hi Garousi,
It's a lot of useful information you put up there. Great job !:D
Recently I ve been busy with other projects, so this has been put on hold for a while. Btw, have you ever put any thuoght on offline map? Internet connection might be an issue if the users are at remote site.
Cheers,
Daniel
Message 20 of 134
(8,669 Views)
