How can i create this?
Hello, I want to receive x and y values of a graph every second and save them in a new text file. How can I create this?
After creating an array, I'm not sure what to do next.
(1,308 Views)
Accepted by topic author wnsl7063
Hi wnsl,
You only need one loop, I would use the first FOR loop.
Create a 2D array from your plot data and write that 2D array with a WriteDelimitedFile function. Use "append"-mode if required...
Do you know we cannot edit/debug/run images with LabVIEW?
(1,298 Views)
Thank you, sir
I made it like this, but there is an issue with the text file. The x-values should be in the first column and the y-values in the second column, but the results appear to be  incorrect.vi.PNGtext.PNG
(1,277 Views)
@wnsl7063 wrote:
Thank you, sir
Just transpose your array, that is:
(1,247 Views)
read the help for the WriteDelimitedFile function!
There is an input named "Transpose?"...
(1,205 Views)
