how to make an input array in a subvi homomorphic
I have a sub vi which performs an operation on an array.  I would like to be able to pass this sub vi I16, -32 and other type numbers and have it give me back the same type of numbers.  As it stands now, If I draw the subvi as an array on the front panel, the representation of the input is "set" and all other types that I try to send to the vi show coercion dots and then output the same representation as the input of the subvi....rather than the type of data I provided.
Any thoughts.
Thanks.
(3,219 Views)
Sorry, that should probably be "Polymorphic" instead of "Homomorphic"....
(3,214 Views)
Accepted by topic author Hummer1
The ability to create polymorphic VIs is included with the professional version of LabVIEW.
(3,212 Views)
Got it thanks.  Once I tried looking up Polymorphic the instructions were quite clear...
Thanks again.
(3,207 Views)
