取消
显示结果
搜索替代
您的意思是:
how to make an input array in a subvi homomorphic
已解决!
转到解答
I have a sub vi which performs an operation on an array.  I would like to be able to pass this sub vi I16, -32 and other type numbers and have it give me back the same type of numbers.  As it stands now, If I draw the subvi as an array on the front panel, the representation of the input is "set" and all other types that I try to send to the vi show coercion dots and then output the same representation as the input of the subvi....rather than the type of data I provided.
Any thoughts.
Thanks.
0 项奖励
1 条消息(共 4 条)
3,187 次查看
Sorry, that should probably be "Polymorphic" instead of "Homomorphic"....
0 项奖励
2 条消息(共 4 条)
3,182 次查看
解答
已被主题作者 Hummer1 接受
The ability to create polymorphic VIs is included with the professional version of LabVIEW.
0 项奖励
3 条消息(共 4 条)
3,180 次查看
Got it thanks.  Once I tried looking up Polymorphic the instructions were quite clear...
Thanks again.
0 项奖励
4 条消息(共 4 条)
3,175 次查看
