isolated usb hub
Dear Sir,
Refer to GPIB Hardware Guide document.
you say,
Use a USB isolated hub. National Instruments does not sell these, but there are many
available for sale elsewhere on the Web or in stores.
I just found an isolated usb hub on (B&B)
http://www.bb-elec.com/product.asp?sku=uisohub4
Do I have other choices you redommended?
Thank you,
(4,265 Views)
We don't have recommendations, but as long as they isolate the different grounds you should be all set.  There are many other isolated USB hubs, and I just found a number by searching for "isolated USB hub."
Mark E.
(4,233 Views)
B&B has a pretty good reputation vs. just any old "whatever technical" is found in a google search. As mentioned, a search for isolated USB hubs will turn up a bunch, but it is also a good idea to then get your hardware from a company that you are familiar with. I've bought related devices (USB to Serial adapters) from a variety of vendors over the years with mixed results.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,218 Views)
