how can i determine which devices are used at the moment?
I can see all kinds of issues with this.  Human issues.  It's probably better so send an email or IM to your colleagues saying you're going to be using the equipment.
Bill
CLD
(Mid-Level minion.)
Message 11 of 19
(1,905 Views)
Hi Gerd,
Okay, I see what you were getting at. Your approach seems the most reasonable.
Message 12 of 19
(1,900 Views)
Accepted by omer32
Use VISA Lock Async.
Your main program can periodically poll the resource lock state and disable the locked VISA Resources.  Make sure you keep a list of "MyLocks" so you don't disable control of instruments that specific bench is using.
"Should be" isn't "Is" -Jay
Message 13 of 19
(1,886 Views)
Jeff,
I don't think the lock works across different computers.
Message 14 of 19
(1,879 Views)
It won't.
Maybe if you setup remote VISA and share the resources through that, but that is really just complicating the setup even more (albeit might allow to get rid of the LAN extender).
Rolf Kalbermatter  My Blog
Message 15 of 19
(1,871 Views)
@Dennis_Knutson wrote:
Jeff,
Right of course-  But updating a NPSV with Lock Status is fairly straight forward
Message 16 of 19
(1,866 Views)
Hi again all,
Jeff, can you explain a little more?
Message 17 of 19
(1,841 Views)
NPSV= Network Published Shared Variable
All of your "User" Systems should be able to write and read to a "Master" location to share information about the usage of the shared devices.
e.g.
  • User A looks for availability of devices it wants by reading the "Lock" or "Checkout" status of the desired devices
  • User A checks out those devices it whants to reserve
  • Begin using reserved devices
If user B wants those devices the NPSV will let them know it is in use already (Hopefully with some additional info like, the name of User A)
  • User B can tap on the cube wall of User A and negotiate whos experiment is more important
  • User A doesn't really need the data so he releases the locks and User B sees that the devices are available again.
-Rinse-Repeat
Message 18 of 19
(1,819 Views)
e.g.
-Rinse-Repeat
That's kind of why I suggested it be handled by humans.  A schedule might help so that you know when the equipment will be available.  (Because you signed up for a time slot.)
Of course this doesn't work well if each person just needs it for a few minutes at a time.
Bill
CLD
(Mid-Level minion.)
Message 19 of 19
(1,814 Views)
