If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
hide tab control
hi
is there anyway to hide/display the tabcontrol while the vi is running?
(3,361 Views)
Sure, just create a property node for the tab control and programmatically wire a true or false ot it to show or hide it, resp.
(This will hide the entire tab control, including any controls on it.)
Could it be you only want to hide some or all of the tabs, not the entire tab control?
(3,354 Views)
Here I made a quick example with two boolean controls:
One shows/hides the entire tab control.
One shows/hides tab #2.
(3,349 Views)
thanks for the answer
let say I am using 2 interface for my front panel, one as the main screen(to let the user chose the mode) and the other as one of the mode selected by the user.
is it recommended to hide/display the interface or is there another efficient way to do so?
(3,346 Views)
There are several different ways to implement the user interface necessary for your application.
One alternative that would allow you avoid hiding and showing front panel controls is to have the main VI call a SubVI that has the user interface for the mode selected by the user. By setting the VI's window appearance to "Dialog" under File>>VI Properties>>Window Appearance the VI will display its front panel when called, and then close after it finishes running.
Scott Y
(3,324 Views)
