General Questions
I just was wondering...
-how many analog channels are there?
-how many bits are these channels and what is the max voltage rating?
-are the inputs differential or single ended?
-what is the maximum common mode voltage?
Say i wanted to use a board to simulate a 2 channel oscilloscope, what should I use as the fastest setting for the timebase?
(2,704 Views)
It would help if you could give the model number of your DAQ hardware. 🙂
(2,703 Views)
The DAQ hardware is an NI 6025E board#
(2,697 Views)
Here is the data sheet for your board. Please repost if you have additional questions.
http://www.ni.com/pdf/products/us/4daqsc202-204_ETC_212-213.pdf
-Alan A.
(2,666 Views)
