extract the positive values of a 2D array
I have a 2D array with positive value in the 2 column.
What I want to do is to find the positive value of each column.
For example, I have this array
A        B
-1        1
2         -2
3         9
5         4
-5        6
6         7
and I want to obtain the following
A          B
3          9
5          4
6          7
I manage to have the positve in each case but the value do'nt correspond (I have all the positive value of each column) like
A      B
2      1
3      9
5      4
6      6
        7
can you help me please ?
(3,497 Views)
Accepted by sf1
Just to be clear: You want the output array to contain all the rows of the input array which have positive values in both column A and in column B?  Are you using strictly positive (>0) comparisons or non-negative (>=0)?  Are the values integers?
Frr answers: Yes and Strictly positive this will do what you want.
Lynn
undefined
(3,472 Views)
Like that?
Zero Included? Simple Integers? Can u provide more information?  Solution may change depending on requeriments Smiley Surprised
(3,470 Views)
I'm using (>=0) comparison and non integers value, and my value are in ligne not column I made a mistake, thank you,
I will try what you send, and I'll come for feedback
(3,411 Views)
Thanks It works perfectly 🙂
(3,383 Views)
