error generation preview
Hello
I'm using LV 13.0 (32) bit.
after finishing my project i decided to generate installer for our customer.
but i have faced with this error :
Application works without any problem .
I have test my project with LV13 (64 bit).
installer generated without any problem .
and I have generated many installer with LV 13 (32 bit).
I don't know why this project has problem.
(4,624 Views)
Hi mori,
How shold we know without knowing your project/LabVIEW installation?
(4,619 Views)
As i said i can generate this project with LV 13 (64 bit)
i couldn't generate with LV 13 (32) bit.
my project attached in this reply
(4,606 Views)
Hey there.
See the article linked below and try the solution there. Also see the LabVIEW 2013 Patch Details- apparently this issue was fixed in the LabVIEW 2013 f2 patch for 32 bit. From that page: "In LabVIEW 2013, including VIs from libraries that have unsatisfied dependencies cause building an installer to fail with error 1 "Error Generating Preview." Hope this helps!
Why do I see "Error Generating Preview" When I try to build an executable application or an Installer in LabVIEW 2013?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8m4SAC&l=en-US
https://www.ni.com/en/support/documentation/supplemental/17/archived--labview-2013-patch-details.htm...
Eden K
(4,563 Views)
