Read from tab delimitted text file and write to csv
Is there a way to read a tab delimitted text file and then write that same data to a csv?
I need to do this, but I don't know how to pass from one type of format to the other.
Can someone please help me?
Thanks.
Message 1 of 11
(6,926 Views)
I just found the answer to my question: http://forums.ni.com/t5/LabVIEW/Comma-delimited/m-p/1204971#M517314
I just need to do the opposite. The problem I have now is that I need to write this info into a csv as a string array, and I don't know how.
Thanks.
Message 2 of 11
(6,923 Views)
The problem I have now is that my app is replacing not only the tab spaces but also the text to ,. How can I fix this?
Message 3 of 11
(6,908 Views)
Hi Nando,
as a CLAD you should know how to write files!
It's the same as with your array question: to create files you will find functions in the file palette! WTF, there are even functions to create spreadsheet files (aka csv aka tsv)!
I think Bob's answer was giving you the way to solve such basic questions…
Edit after noticing your 3rd post:
When you process files as "raw" text you should save them as "raw" text using simple WriteTextFile function.
If you would use ReadSpreadsheetFile to read your tab-separated file you could easily use WriteSpreadsheetFile to save the data as CSV…
But whatever you do: don't mix the options (as long as you don't know what you're doing as it seems right now)!
Message 4 of 11
(6,905 Views)
I thought I could use the replace array subset, so I can still use the read from spreadsheet vi, but I don't know if that is the right way to go?
Message 5 of 11
(6,896 Views)
Hi Nando,
read the TSV, save as CSV:
Or stay with plain text:
Remark:
You really should NOT edit your questions to something completely different while someone else is answering you!
Message 6 of 11
(6,891 Views)
what is the vi that goes connected to the read from spreadsheet vi called?
Message 7 of 11
(6,877 Views)
I just realized its a write to spreadsheet vi.
Message 8 of 11
(6,845 Views)
I did as you  told me, but the write to spreadsheet writes all the info in just one cell, instead of multiple columns.
could you please help me again?
Message 9 of 11
(6,738 Views)
Another quick question.
How would I read all the lines in a spreadsheet, except the first one?
Message 10 of 11
(6,733 Views)
