error code -200081
I am trying to calibrate a NI 9211 unit but I keep getting the following error code.
Error or termination occurred. This calibration may not be valid. Error code: -200081 Error message: Error -200081 occurred at DAQmx Start Task.vi at step Verify Analog Input:1 Number of Channels: 2 Sample Rate: 7.140001 Maximum Sample Rate: 6.000000
I am using CalExec version 3.3.2. Is there a fix to this problem?
Ryan A. Saunders
Idaho National Laboratory
Standards and Calibration Lab
phone: (208)526-2202
email: Ryan.saunders@INL.gov
(3,953 Views)
Hi Saipanman,
Which DAQ Chassis are you using??
Are you are using a single Module Carrier such as a NI USB-9162 or are you using a cDAQ chassis such as the NI cDAQ-9172?
Nathan
National Instruments UK & Ireland
(3,937 Views)
The user has it in a NI USB-9162
(3,931 Views)
Hi Saipanman,
Calibration is only possible will a Chassis such as the 9172 as this is not available for the single module carrier such as the 9162.
If you are able to, try using a Chassis to perform the calibration instead.
Nathan
(3,917 Views)
Wilson54910
Great info Smiley Happy
thanks for your help.
Totally Kudos
(3,898 Views)
