error -2558
I am using Labview 7.1 and I encounter this eror -2558 when using the "Open Storage (TDM)" function. Can anyone tell me what is that error? Under the "Open Storage (TDM)" function, i use the default file location as given, it still give me that error...
I have attached the VI file.
Inside the folder, all I can see is a text file showing:
c:\xml4c_root\xerces-c-src2_2_0\src\xercesc\framework\LocalFileFormatTarget.cpp(94) : fatal error xercesc::IOException : Could not open file: C:\Program Files\National Instruments\Shared\USI\DataModels\USI\TDM\1_0\USI_TDM_1_0.xsd
Any suggestion?
Sebastian
(3,725 Views)
Sebastian,
This error is explained in the following knowledge base article
Hope this helps,
Justin D.
Applications Engineer
(3,710 Views)
This link is broken
(1,911 Views)
