Invalid String Data, Keithley DAQ 6510
I get the following error message with the Keithley DAQ 6510.
The voltage measurement works without any problems, whereas I get the attached error when measuring the temperature. The VIs are provided drivers for the Keithley model. I have tried troubleshooting with NI IO Trace, but have not been able to figure it out. Does anyone have a tip for me?
Thank you very much.
(2,050 Views)
I see "Fehler", so I assume you are on a computer with German settings.
Often instruments drivers are not written for a system with a comma as the decimal point character.
Change your LabVIEW settings to NOT use the localized decimal point and try again.
Regards, Jens
Kudos are welcome...
(2,028 Views)
Thanks for the quick reply. Unfortunately, it did not work. Is it possible that a LabVIew version with a different language would work?
Best regards
Özgür D.
(1,978 Views)
Hi Özgür,
can you debug the Keithley VIs to find the offending string, which triggers the error -151?
Once you have found the wrong command you can compare it with the description in the manual and finally correct the device driver VIs to avoid that error…
(Remark: As indicated by Jens' suggestion device drivers often fail when the computer does not use the English numeric formats. I also observed such problems regularly. And I learned to revisit device drivers as they most often don't do what I really needed…)
(1,964 Views)
