error 1059
Hello ,
What does the following error mean:
Error 1059 occurred at Open/Create/Replace File in Write Spreadsheet String.vi->Write To Spreadsheet File (DBL).vi->MAIN 4-9-12 dev 7.vi
Possible reason(s):
LabVIEW:  Unexpected file type.
C:\Users\Raman\Desktop\DAQ TEST DATA
The VI is attached below
Thank you
Abhi
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 8
(17,151 Views)
It looks like you specified a path to a subdirectory called DAQ TEST DATA rather than to a file.  The unexpected file type is that it is a folder rather than a file.
Add another backslash and a file name to your path constant.
Message 2 of 8
(17,148 Views)
Thanks for the reply ...
oh does that mean it will only write to a file that was already created ?
What If I want to create a new file everytime i run the program so that it asks me to save it in the folder with a new file name ( save as ) option like how it is in windows ?
Thank you
Abhilash S Nair
LabView Gear:
Message 3 of 8
(17,146 Views)
Have a look at the "File Dialog" function.
File I/O ->  Advanced File Functions -> File Dialog
Message 4 of 8
(17,139 Views)
You can pick any filename you want, it doesn't have to exist.  But there does have to be a filename and not just a path to a folder.
Message 5 of 8
(17,133 Views)
you h to connect the path to a build path and in the build path write your filename.txt
Message 6 of 8
(15,434 Views)
I just uploaded a picture with the code.
Message 7 of 8
(15,427 Views)
Since this is the first result on google I'll throw my situation in here:
Was getting error 1059 during a source distribution build on a method VI of a class which was perfectly fine. However the class was in the same hierarchy as another class that had a different VI that was set to the wrong reentrancy as other dynamic dispatch VIs. Fixed the reentracy in the other class and the source distribution completed successfully.
~ Helping pave the path to long-term living and thriving in space. ~
Message 8 of 8
(2,247 Views)
