Is it possible to connect a high speed camera and a load cell to Modbus RTU for synchronization?
I am working on a Modbus RTU VI for a motor, and I need help connecting a load cell DAQ and a high-speed camera for synchronization. I have attached the VI for help.
(741 Views)
can you save code for version 2020 ?
(714 Views)
Hello, I have attached the code version for 2020 for your review.
(711 Views)
What are your synchronizations requirements?
What are the details of that high speed camera? Interface, protocol, make, model?
The question in respect to Modbus RTU and high speed camera and synchronization sounds like you have a fairly limited understanding of the technologies.
Modbus RTU is definitely NOT a realtime NOR a high speed protocol. But it always depends on your requirements. If several 100ms accuracy in synchronization is enough, it MAY be an option.
But with the few terms you throw at us, that sound potentially very incompatible with each other, we really can't do much.
You need to specify in much more detail what you really want to do. And most likely the solution is not quite what you currently expect.
Rolf Kalbermatter  My Blog
(684 Views)
