1.25M messages in the LabVIEW board
Having started this history a long time ago, I'm continuing it by adding the achievement of a new "250k" milestone.
The graph shows the significant decrease in the number of messages per day.
  • 250k : May, 20, 2007
  • 365k :  October, 30, 2008
  • 500k : May, 27, 2010
  • 750k : July, 22, 2013
  • 1M : July, 5, 2017
Message 1 of 10
(21,455 Views)
It's quite simple, actually.  Everyone has finally learned everything about LabVIEW from the forums, so there is no need to come here and post.  😉
Actually, that's almost the real explanation, although not the root cause.  The root cause is there are fewer and fewer new developers, so less questions are being asked.  At least, IMO.
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(21,421 Views)
I think usage of LabVIEW has fallen a lot and you'll find a lot of correlates showing that.
Message 3 of 10
(21,366 Views)
It is definitely interesting data.  But I can't help but notice it started dropping off in 2017 and that was when NXG 1.0 was released.  I am not saying it caused it, just pointing out the timing.
Message 4 of 10
(21,339 Views)
It may be a correlation but I'm not quite sure a cause. The first slowing down can be already seen from 2013. That is about the time NI decided they needed to do something else than selling DAQ boards to be able to keep growing with 2 digit numbers year over year. They set out to conquer vertical markets by building entire test systems rather than test system components. They made very little noise about that as it was directly going to compete with their traditional partners, but they build a strategy to go that path nevertheless. A few years before they also had decided that LabVIEW was difficult to maintain and keep developing and had started a project to create a new platform that eventually was called LabVIEW NXG.
At about the same time it was slowly noticeable that NI people were getting less involved in answering questions on the forum. Also many products started to get discontinued, partly because of necessity because parts were hard or impossible to source anymore, partly to consolidate the manufacturing towards high volume products with good margins and get rid of low volume products that were more and more expensive to support. And around 2017 it was getting more and more noticeable that NI people while not getting punished for being active on the forum, also didn't really get any rewards or incentives for doing so. This naturally led to them disappearing more and more from the forums with the exception of a few diehard enthusiasts. So yes the numbers clearly show a diminishing number of posts but that is also because NI itself got less and less active on the forum. First because the missing posts of NI people directly affected the post count, second because many questions were mostly answered by some voluntary enthusiasts who had their own criteria what to answer and how professional to be with that.
That the number of active users also dropped for sure didn't help, but which was the chicken and which was the egg could probably be debated about quite a bit. 😁
Rolf Kalbermatter  My Blog
Message 5 of 10
(21,276 Views)
In addition, here is a comparison of the number of days elapsed and the number of posts per day for the 250k milestones. Unfortunately, as I don't know when the forum was launched, I can't give the values for the first milestone.
This shows the variation even more clearly.
Date Messages [M]  Elapsed days [-] Messages/day [-]
20/05/2007 0.25
27/05/2010 0.5 1103 227
22/07/2013 0.75 1152 217
05/07/2017 1 1444 173
05/08/2024 1.25 2588 97
Message 6 of 10
(21,220 Views)
the first post is Lakeshore 340 Temperature Controller - NI Communit, ‎1999-05-19 05:33 PM
Message 7 of 10
(21,120 Views)
Hhmmm ... 🤔
https://forums.ni.com/t5/LabVIEW/data-banks/td-p/1  1999-05-08 07:27 PM
Message 8 of 10
(21,111 Views)
There was a phase, I think starting even before 1999 where NI had already a forum but all being new it was not very much frequented directly. Instead they had a gateway to the LabVIEW mailing-list server they had setup earlier. I preferred the mailing-list format to the forum solution a lot, since there wasn't yet an always-on internet connection but you had to dial-up to an internet provider, initiate the synchronization with the mailing-list server and then disconnect and go through the posts, answer whatever you wanted to answer and then connect again and all the answers were sent to the mailing-list server.
The gateway would regularly scrape the mailing-list server and add each message thread to the forum. The messages shown here might be from that, but they generally looked more teletype like in their format. 😁
It also had the problem that depending from which computer you connected to the mailing-list and which exact email address was used for that connection, the gateway wasn't always able to associate posts to the same user account. I have (or had) several accounts in the forum because of that. There was a time when one could contact the NI forum manager (Laura I think) to have such accounts merged but by the time I learned about that the forum software had changed multiple times and merging of accounts was apparently a feat that required super human powers. 😁
Some of those messages definitely seem to have gotten lost in the deep cracks of information archeology.
Message 9 of 10
(21,099 Views)
It used to be the case that TSEs had to monitor forum posts and make sure there was at least some response (you didn't have to respond yourself if there was good activity). I think it was round the 2016 timeframe where that stopped being the case.
I thought the quality of the TSE responses was generally pretty poor because you were never judged against whether the issue was resolved or that you had good suggestions, just that you responded within the specified timeframe. When I was at NI there was also never any incentive to post in the forums.
Message 10 of 10
(21,054 Views)
