disable entire group of controls at once
Is there anyway to disable a group of controls that are grouped together on the front panel at once?  I know how to disable each one individually, but I have a lot in a group that I would like to all disable together.
Message 1 of 9
(3,778 Views)
Hi rakornet,
you can cluster all your elements and hide the entire cluster, or you search for all references and go through a loop to hide them seperatly.
Mike
Message 2 of 9
(3,774 Views)
.... or put them all in a single page tab control that is transparent and just disable the tab control.
Ben
Message 3 of 9
(3,768 Views)
That's a clever idea, Ben. And, it wouldn't impact existing code like putting the controls into a cluster. I never thought of that. I like it!
Message 4 of 9
(3,738 Views)
Ben
Oooh, now that's a good idea!  I'll have to remember that one.
Jon D
Certified LabVIEW Developer.
Message 5 of 9
(3,732 Views)
Ben,
That sounds like a great idea, but I can't color my tab control.  What am I doing wrong?  LV8.0.
Jim
LV 2020
Message 6 of 9
(3,721 Views)
Are you using the classic style tab control?
Ben
Message 7 of 9
(3,716 Views)
Well I guess so!  Thanks.
Jim
LV 2020
Message 8 of 9
(3,713 Views)
The tab control method works (I've used it myself more than once), but does have some disadvantages. As mentioned, another option is to go over the references in a loop. Here's an example which shows moving this off to a subVI. This has the advantage of making complex UI code relatively easy to handle.
___________________
Try to take over the world!
Message 9 of 9
(3,697 Views)
