How do I convert labview code to text code?
I have a complicated LabView code given by a device maker (LakeShore). I want to convert it to a simpler LabView code. I think that the best way to do that is to first understand their algorithm. Is there a way I can "convert" the Labview code to a simple, text algorithm?
Amit.
(3,497 Views)
Accepted by topic author Finkler
No, but if the code is fully available, you can do some refactoring and cleaning up to better understand what's going on. Usually, just cleaning up the code and documenting each section using comments makes it easier to understand. Also, you can use the Edit>>Create SubVI option to encapsulate pieces of the code into VIs to make it easier to read.
Just note that all this requires being careful so that you don't change the functionality of the code.
___________________
Try to take over the world!
(3,487 Views)
