delete column in database
Hi All,
Ca anybody Explain me how to delete the perticular entire column  in a table.
Srinath
Message 1 of 12
(5,618 Views)
I think you can not delete a complete coulmn from the table in the database.
either you have to create new table in the database.
or else you can delete values from the selected cloumn by writing delete query. (
DELETE FROM table_name
WHERE some_column=some_value)
Regards
Prabhakant Patil
Message 2 of 12
(5,613 Views)
Just note for you
WHERE clause in the DELETE syntax. The WHERE clause specifies which record or records that should be deleted. If you omit the WHERE clause, all records will be deleted!
Regards
Prabhakant Patil
Message 3 of 12
(5,609 Views)
It is possible to delete all rows in a table without deleting the table. This means that the table structure, attributes, and indexes will be intact
Use following query
or
DELETE * FROM table_name
Regards
Prabhakant Patil
Message 4 of 12
(5,608 Views)
Did you even try a google search for deleting a column with SQL? Of course not, otherwise you would not be asking the question, I guess. Why you think this is a LabVIEW question, I have no idea, though. Look up the ALTER TABLE syntax.
Message 5 of 12
(5,595 Views)
Correct.
Just Check with the SQL Help
Regards
Prabhakant Patil
Message 6 of 12
(5,585 Views)
Do you want to delete a column, or change the value of a field (column name) of all records to nothing (NULL).
If you want to clear/change to NULL then you can use an UPDATE statement, but this is not something that you 'just play around with'
Spoiler
UPDATE table_name SET column_name = NULL
Message 7 of 12
(5,572 Views)
Example of Update statement is
UPDATE table_name
SET column1=value, column2=value2,...
Regards
Prabhakant Patil
Message 8 of 12
(5,560 Views)
Hi Patil,
Can you Explainme how to rename the Column name in a table
srianth
Message 9 of 12
(5,554 Views)
You can use foolwing statement to rename column name
sp_RENAME 'TableName.[OldColumnName]' , '[NewColumnName]', 'COLUMN'
More in details
USE [Database name]
GO
GO
Regards
Prabhakant Patil
Message 10 of 12
(5,545 Views)
