03-23-2017 10:47 AM
I have a problem opening an accdb with database toolkit the second time I try to open the database.
Error: ADO error catastrophic x8000FFFF (something wrong with the database cursor?)
See attached vi for code.
regards,
Koen.
03-23-2017 10:58 AM
Are you asking about the second time you open access the DB OR are ou saying the attached code fials the second time you run it?
If it is the former, are you closing the connection and trying to re-use a closed reference?
Ben
03-24-2017 02:55 AM
Hey Ben,
it is not only the former, it is both. As You can see in the code, I open the database, I execute queries, and I closes the connection. The second time, the open fails with ADO error x8000FFFF (catastrophic error).
As I googled, I found Microsoft commented on a same issue with SQL database, commenting something about the cursor of the database.
Koen.
03-24-2017 08:00 AM
Have you watched the code you posted run in Execution Highlighting(turn on the light bulb) mode?
What part works and what happens between when it works and when it fails?
Ben
03-24-2017 08:33 AM
Hey Ben,
yes I did. First time, everything OK, second time, Error as described (catastrophic x8000FFFF) after DB Tools Open Connection.
When I only Open & Close (without the Execute & Free), everything works fine.
I'm using ODBC v16 (MS Access /Office 2016).
I'm assuming and thinking (90% or more sure) that all works fine with MSAccess 2007.
I already posted the more or less the same issue (using labSQL i.s.o. Toolkit on a MSAccess 2016 redistributable installed PC giving error x80004005) on the MSDN forum.
regards,
Koen.
11-06-2019 11:42 AM
I had this same issue running LabVIEW 2017 32-bit, Windows 10 64-bit, and Office 32-bit.
My solution was to clean install the AccessDatabaseEngine.exe for 32-bit.
Seems to run perfect now.
