compile worker cannot perform compilation, local compiler
I've reinstalled the Xilinx tools. Unfortunately that did not fix the problem. The same error messages persist.
Message 11 of 16
(990 Views)
What version of the Xilinx compile tools are you installing?
Message 12 of 16
(978 Views)
Version 14.7
Message 13 of 16
(970 Views)
Is there another program you could try to compile to see if the issue is associated with various versions of the code that you are trying to compile now. Also, could you try doing a repair of LabVIEW through the control panel to see if that helps resolve the issue.
It seems that uninstalling and reinstalling the Xilinx Tools is the best way to work through this error, but it seems that did not work for you.
Message 14 of 16
(952 Views)
Maybe I didn't uninstall it correctly. What exactly is the best way to uninstall the program?
Message 15 of 16
(944 Views)
Check in Programs and Features. It should be in one of three places:
1. Standalone in Programs and Features
2. Under National Instruments Software
3. Within the LabVIEW FPGA installer. You would have to change/modify this installation if the tools are here.
Once you find it in one of those three places, a normal uninstall should do the trick
Message 16 of 16
(935 Views)
