building an application with daq software
Hello all.
I am having trouble building an application that uses two vi's that use daqmx specifically NI cDAQ-9174 with NI 9041 collecting a voltage and displaying a digital signal.
I want the program to be able to run on any computer sans LabVIEW, just needing the USB connected. The program opens, and does not run in to errors, but it does not capture any data leading me to believe there is some issue with the daq device. How can i configure my build so that it can read the signal?
If you need any more info feel free to ask.
Neil
Message 1 of 10
(4,829 Views)
My guess is that you need to configure the device in MAX to match the name and other settings from your developement computer.
Message 2 of 10
(4,823 Views)
When you build the installer, the hardware configuration from MAX can be included as well as the DAQmx runtime. Did you also include MAX? Does it work there?
Message 3 of 10
(4,800 Views)
Good thought. Do I include that in the lvproj?
Message 4 of 10
(4,790 Views)
No, you include it in the installer.
Message 5 of 10
(4,770 Views)
Yes.  You can add DAQmx Tasks, devices, channels, etc to the project.
Message 6 of 10
(4,767 Views)
I never used the installer before, is that the same process as making an application? So just put MAX in the source files?
Message 7 of 10
(4,758 Views)
It is similar.  The installer also goes into the Build Spec.  It allows you to have files put in specific locations, create shortcuts, install required drivers, etc.  One of the things you can put in the installer is a DAQmx configuration that you created from MAX.
Message 8 of 10
(4,753 Views)
Now how do I get one task out of MAX. I keep just adding the NIMax.exe
Message 9 of 10
(4,744 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2H7CAI&l=en-US
Message 10 of 10
(4,699 Views)
