abc
Hi Saif, could you attach your code as image? I'm not on my PC right now. Have you try to delete those two DO DAQ Assistant? I recommend you to look at NI Example by click Help>>Find example>>Hardware IO>>daqmx. Hope the example could help you.
Message 21 of 28
(2,244 Views)
Hi Bill,
I can go upto 8 but not 7!
Saif
Message 22 of 28
(2,238 Views)
Hi taov,
Image attached.
I am trying to replace Assistant Express VI's with the standard DAQmx VI's.
Cheers,
Saif
Message 23 of 28
(2,236 Views)
I can't see the image. No attached image there
Message 24 of 28
(2,231 Views)
sorry, here it is...
Message 25 of 28
(2,228 Views)
Your DAQ task that you setup is also using that same lines yoiu have set up in DAQ Assistant 2 and DAQ Assistant 3.  Then you fail to stop and clear that task when your program ends.
Message 26 of 28
(2,218 Views)
Saif, try to use daq-mx function vi instead of daq express. Open the ni example i told you before and try to build your vi based on those example. You can make your analog measurement in one loop and your digital output in another loop.
Message 27 of 28
(2,207 Views)
I'd recommend a Clear task at the end of the program. LV should handle it, but it's a good standard, just like you'd Open and Close a file or Visa-resource.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 28 of 28
(2,198 Views)
