Why does my numeric control flicker?
I have the most simple VI attached to demonstrate this problem. Why does my numeric control flicker?
More importantly, how can I stop this annoying flickering?
Message 1 of 11
(5,087 Views)
It doesn't appear to flicker when I run your VI.
Issues with your video driver?
Message 2 of 11
(5,080 Views)
Not an issue with video driver "probably", as it happens on three separate machines, all running the latest Windows.
Message 3 of 11
(5,078 Views)
just to confirm, I also see the flicker. I'm wondering if it's some sort of screen refresh you're seeing.
Message 4 of 11
(5,074 Views)
And do those machines all use the same video driver?  Do you have a machine that has an older version of Windows?
All I can tell you is that it is not a problem with your code because on my machine (Vista with LV11), that is one data point showing that it works okay.  Maybe a few other people can attempt your code and will weigh in whether it works for them or not.
Message 5 of 11
(5,073 Views)
Accepted by bmihura
Why is the indicator set to "Synchronous display"? Turn that off!
Where did that indicator come from, specifically, why does it turn blue if I color the background transparent???
Have you tried selecting a specific font that is guaranteed to be available on all computers?
Message 6 of 11
(5,068 Views)
Flicker FREE for me, W7 64 bit with a high end video card.
Message 7 of 11
(5,055 Views)
OK I have re-built it from scratch, and am happy with it. Don't waste your time on it, but why did my original code not work? Again, don't waste your time on it unless you want $100 PayPal and waste a lot of time on these forums.
Message 8 of 11
(5,053 Views)
I don't consider my time on the forum wasted. I learn a lot here.
Message 9 of 11
(5,045 Views)
Sorry, not to be rude, but what the hell does this mean?
Message 10 of 11
(5,033 Views)
