How do I let the user input values at specific times ?
Greetings Gentlemen,
I'm trying to make a program which can take some values from the user at specific times only
The goal of the program is to formulate a calibration equation for the Thermocouple.
Thermocouple's output is in millivolt, and it's taken from the Digital Multimeter after each " t " minutes.(x-axis readings)
I want to prompt the user at these times to input the value of the temperature.(y-axis readings)
I want to organize all of the input in a table(array?) and let LV do the graph and output the equation.
Can LV do all of this?
Thank you very much
(2,852 Views)
Yes it can. I would recommend you look at the examples for how to implement a state machine. This will allow you to prompt the user and specific times when you need the data. You can prompt the user by using dialog boxes or by simply showing/hiding the controls at the appropriate times.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,849 Views)
Can you tell me where can I find it?
(2,837 Views)
you might want to learn google search Smiley Very Happy
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
If you combine this with a shift register where you keep the last time stamp, you can check the elapsed time by substracting the current time by last time stamp and see if its bigger then a certain value...
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,819 Views)
