While Loop Help...I think
All,
I have a fairly simple VI that grabs the units of measure (send a "A") from a MARK-10 test stand and MARK-10 force gauge. I'm struggling with how, or where, I should place my While Loop. What I would like the VI to do is if the units of measure are not correct, change the units (send a "U") and retry the comparison.
Thanks in advance.
(4,572 Views)
Accepted by BadAzzS10
Like this?
Edward Motts
Certified LabVIEW Associate Developer
(4,554 Views)
That looks like it would do what you want it to do. I have two observations that may improve your design.
1. Is it guaranteed that the unit will be two bytes long at the beginning at index 7? I would recommend using the match pattern vi and if the substring is not found the offset past match will be -1.
2. The close port probably should be outside of the loop and shift registers are good too unless you want to loose any previous error details.
-Nate
(4,548 Views)
N8D11,
I agree that the close port should be outside the loop--you wouldn't want to close that port on the first iteration.  My mistake.
Ed
Edward Motts
(4,532 Views)
That did it. Thanks!
(4,503 Views)
