Do the serial port drivers for LabView 7 work on Windows 7
I created an application using LabView 7.1 that has run on Windows XP.  I tried to install this app on a Windows 7 based PC and the serial port communication no longer works.  I have installed the latest version of NI-VISA but still does not work.  Reading through the other discussions, upgrading to a new version of LabVIEW is necessary but is there another solution?
(4,263 Views)
When you say the serial port drivers, are you referring to the old serial port drivers that used port I/O functions? If so, they won't work. You will need to update the code so you use VISA.
And, yes, LabVIEW 7 is not supported on Windows 7.
(4,262 Views)
I do use VISA.  Is there a work around if i am using VISA?
(4,254 Views)
Accepted by topic author Robb@Switch
There is no workaround. The latest version of VISA does not support LabVIEW 7. The earliest version of NI-VISA that supports Windows 7 is 4.6, and that does not support LabVIEW 7. You need to either upgrade LabVIEW or use an older OS.
(4,249 Views)
