What is a TDO?
I have a newb kind of a question. Can someone explain to me what a TDO is as it would apply to data locations for scripts. I use Labview at work to test PCBs, and when writing scripts I have to set TDOs in a certain order.
I was just looking for what TDO stands for and and an overview of what they are.
Thanks very much!
George
Message 1 of 9
(7,053 Views)
Why don't you provide us some context?  You obviously saw TDO used in some sentences -- why don't you quote them for us?  [I confess I'm not 100% certain I know what a PCB is, only 97.3% ...].
Message 2 of 9
(7,032 Views)
Type Descriptor Object?  No, I don't think that is the definition you are looking for.  Here is a list of 31 possibilities.  As was already stated, a little more context would be helpful.
Message 3 of 9
(7,011 Views)
When using a CAN bus monitoring software, there are some addresses, or "bit place holders" labeled TDOs. That's really all I know about them.
Thanks again!
George
Message 4 of 9
(6,989 Views)
Thanks again!
George
That's NOT all you know about them.  You know there is a document where this is located.  Maybe you can share that with us.
Bill
CLD
(Mid-Level minion.)
Message 5 of 9
(6,987 Views)
Accepted by gsrokmix
So I found a basic answer. CAN is a protocol similar to OBDII. We use Labview to monitor & test CAN based hardware. There are 3 different versions of CAN. TPDO (I didn't get the acronym) represents lines of CAN commands for one version of the protocol.
Thanks very much for the replies!
George
Message 6 of 9
(6,965 Views)
TPDO = Transmit Process Data Object
-AK2DM
Message 7 of 9
(6,938 Views)
Ahh, thanks so much for that.
George
Message 8 of 9
(6,934 Views)
Obviously a Tunnel Diode Oscillator, use them all the time for high precision measurements since they have a region of negative I-V characteristics and can be made to stably oscillate with sub-PPM stability.
Not what you were looking for?  Seems that the field of 3 character acronyms is very very overloaded!
LabVIEW ChampionLabVIEW Channel Wires
Message 9 of 9
(6,899 Views)
