Using Labview to control spark ignition
Hello everyone,
I am currently working on a project that requires me to ignite fuel and oxidiser using a precisely timed spark ignition. In order to time the ignition signals do I need to program the Ignition control module using Labview (if possible)? or
I won't require the ignition control module and just use a TTL ciruit?
I appreciate your help.
Message 1 of 14
(3,477 Views)
What hardware are you using?
Santhosh
Soliton Technologies
Message 2 of 14
(3,468 Views)
Unless you're running LabVIEW "Real-Time", i.e. using the specific "Real-Time" version of LabVIEW, plus running it on dedicated hardware with a real-time OS, it's quite unlikely that you can do this.
If you're just running it on Windows or Mac or whatever, those operating systems have nowhere near the timing reliability that you would need.
But tell us more about this "Ignition control module", as that might be programmable with LabVIEW.
Message 3 of 14
(3,455 Views)
Where does the signal to control the ignition timing come from? What is the timescale? (nanoseconds, microseconds, milliseconds?). Again, what's the hardware? Do you need to acquire data before|during|after the ignition? What else is there?
Message 4 of 14
(3,453 Views)
I am using an automotive ignition arrangement consisting of a spark plug, ignition coil, battery and ignition control box. The spark timing must occur at time intervals of milliseconds. The ignition control box or ignition control module I am referring to is what is used in cars to time the spark ignition by controlling current to the spark plug.
Message 5 of 14
(3,433 Views)
If you have all the parts, why do you need LabVIEW again?
Message 6 of 14
(3,431 Views)
The system I am working on requires timed opening and closing of valves to feed fuel and oxidiser in a chamber and ignite it. To control system timing I need Labview.
Message 7 of 14
(3,424 Views)
@Magicdust wrote:
requires timed opening and closing of valves ...
So there are the *real* requirements.
As other have pointed out, you will need a real-time OS or an FPGA or a PLC... I guess LV could be involved if you really want it to be. 😎
Message 8 of 14
(3,418 Views)
I see. Although I dont' have much idea about using real time OS but I will find about it. Thank you for the help.
Message 9 of 14
(3,412 Views)
I have a different, more hopeful thought.  I've been involved in several threads related to ignition timing systems over the years though it isn't something I've ever worked on personally.
In many, probably *most* cases, the ultimate driver of timing was an encoder attached to the crankshaft.  This allowed timing signals to correlate to rotational *position* despite variable rotation speed.  And generally the data acq gruntwork was done with a multifunction DAQ board, without needing to resort to on-the-fly decision making in RT software or on an FPGA.
Do you (or can you) have an encoder on your crankshaft?   If so, an X-series MIO board may be able to do what you need.  Or a small cDAQ chassis with 1 analog and 1 digital module.
-Kevin P
Message 10 of 14
(3,378 Views)
