Create a map for the robot 2D array
I want to create a map of the receiving robot using an array. Where 0 is closed place and 1 is open place
Message 1 of 8
(2,706 Views)
Hi hamada,
And what's your question/problem?
Why don't you create such an array?
Message 2 of 8
(2,696 Views)
I don't know if my english is good or not I desperately need help I'm working on a receiving bot. I want to define and create a map of the room, since 0 in the array 2D is a closed place and also 1 is an open place. How is that Can someone send me the file
Message 3 of 8
(2,647 Views)
Definition of a map on LabView, where 0 is a closed place and 1 open place
I do not have enough experience in the program
Message 4 of 8
(2,645 Views)
Your English is good enough for me to understand that you desperately want someone to do your work for you.  You might want to post here to see if you can pay someone to do it for you.  Or you can provide us with what you have done so far and we can guide you in your quest to develop code that will do what you need it to do.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(2,645 Views)
Hi hamada,
Please don't create multiple threads for the very same problem. Stick with your thread…
When you want to gain experience you shoudl start with the Training resources offered at the top of the LabVIEW board.
And it surely would help to show the expected result of your requirement and to explain the way you want to achieve this result…
Message 6 of 8
(2,636 Views)
Using LabVIEW, I want to know a map using a 2D array, where 0 is a closed space and 1 is an open space
Message 7 of 8
(2,582 Views)
Hi hamada,
I already told you not to start new threads for the very same topic, but again I merged your new message…
I repeat: provide examples of the required results!
Message 8 of 8
(2,571 Views)
