Using Greek Symbols in text objects
I'm looking for a technique  that allow to insert Greek symbol (e.g. alpha, betta) into text object.
What I've found until now doesn't work in my version 2015.
In most cases the solution is based on calling font interface (ctrl+0).
Indeed, font dialog appears, but there is no symbol map - just font selection, size and features (bold, italic, etc.).
How can I put let say "LAMBDA" symbol in my text object.
Thanks in advance.
Pavel
(4,273 Views)
Accepted by Pavel_47
Hi Pavel,
Select the "Symbol" font (I guess you are using a Windows pc) and type "l"/"L"…
Example:
(4,259 Views)
Hi GerdW,
I forgot to change for "Symbol". It works even more simpler - e.g. for DELTA, I've used Shift+D (once "Symbol" was selected).
Pavel
(4,244 Views)
