Everything works when no FPGA is used. So the harware and circuit are working.
However when targeting FPGA module on MyRIO, the data acquisition and processing works and the signal to the motors is "sent" (visible when Hightlight Execution is enabled). But there is no voltage on the DIO ports used. The FPGA projects includes VHDL code.
Do you know what might cause this problem?
