Labview 2011 crashes at error 404
Test rig monitors and saves data from analog sensors, Recently it has started to crash at apparently random intervals ( has run for years before recent incidents). Only message on event veiwer is Labview error 404 at time of crash. S/W crashed up to 5 times/day. However, didn't crash overnight or weekend (running 24hr/day). Now it has run 1.5 day without incident,
copy of test rig vi attached.
Labview version:  2011.
PC: HP Compaq
OS: Windows XP
DAQ chassis: SCXI 1000
Comms: PCI-MIO-16XE-50
(4,018 Views)
Unlike gears, software doesn't wear out. If it suddenly stops working something has changed. What has changed? What only happens during normal business hours?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,980 Views)
If it is only crashing during business hours, is there some event or process that is occuring every time the program crashes?
Also, is this generating a LabVIEW crash report?
(3,966 Views)
I thought it might be due to some background IT maintenance task. I don't have admin rights so awaiting our IT to confirm. Oddly, the rig has now run for 2.5 days without incident. Last week was plagued by failures (5 or more /day). How do you generate a Labview crash report? The only errors I have noted are those in the event viewer log, Labview error 404 appearing at exact time of failure.
This is only a recent mode of failure, rig has run for years without incident. There have been no changes or updates to any of the rig s/w or the PC. The PC is only used for this test rig and nothing else.
(3,951 Views)
If LabVIEW crashes and prompts you with the option to send the information to National Instruments you can select yes and it will send us some information then generate a zip file that contains some information about the crash.
Sometimes it generates a report but doesn't tell you and will save it in a default directory.  The link below should explain where the error logs are stored if you have any.
http://digital.ni.com/public.nsf/allkb/7E9EBE4CA3B6DCE786257633005E7121?OpenDocument
(3,930 Views)
