Turn Off NI Application Web Server
Our NI System Web Server service will not start and has the following error.  Any and all assistance would be helpful.
Faulting application name: SystemWebServer.exe, version: 13.5.0.49152, time stamp: 0x52a7c230
Faulting module name: MSVCR90.dll, version: 9.0.30729.8387, time stamp: 0x51ea24a5
Exception code: 0x40000015
Fault offset: 0x0005beae
Faulting process id: 0x3970
Faulting application start time: 0x01d277da506eea85
Faulting application path: C:\Program Files (x86)\National Instruments\Shared\NI WebServer\SystemWebServer.exe
Faulting module path: C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_5094ca96bcb6b2bb\MSVCR90.dll
Report Id: 8e287da8-e3cd-11e6-8104-00155d6abb00
Faulting package full name:
Faulting package-relative application ID:
(6,601 Views)
Try to reinstall?
Can it be windows network/security restrictions?
Try to start manually? Start -> Run (or win 10 cortana text) -> type "Services" -> Run it -> find NI System Web Server -> start it
Change Startup type in Right click -> properties to Automatic (Delayed start) from Automatic  if helps
We would appreciate LV version (full or run-time), operating system, when does it happen (on windows startup?)
Also "NI application web server" is different from "NI System Web server"
(6,572 Views)
Wow, my problem to the tee... even to the offset.  the NI System Web Server will not start and shows this error in the event viewer.  what did you have to do to fix this???
(4,990 Views)
What error? Is it what you posted earlier?
EDIT: Never mind, that looks like an event viewer error.
(4,979 Views)
The error is caused by an exception of the application...
The application is either corrupt, or it's the configuration (since the app is running on most systems). Perhaps you can clear it somehow?
A repair or uninstall\install makes sense.
(4,976 Views)
