取消
显示结果
搜索替代
您的意思是:
Turn LEDs on using the RS232 port
I would like to know if it is possible turn on a sequence of LEDs using the serial port (RS232). If it is possible, how can I do it?
I use LabVIEW 6.0
Thanks and regards.
0 项奖励
1 条消息(共 7 条)
3,321 次查看
You could turn on a couple of LED's wired between the DTR and ground pins, and RTS and ground pins.  Then you can use the property nodes for the serial port in Labview to set them to True or false to turn on and off the pins.  But this is only 2 outputs.  I'm not sure if that is much of a "sequence".
2 条消息(共 7 条)
3,320 次查看
Thanks Ravens Fan, but what do you think about to use the parallel port? I need at least five outputs.
Regards.
0 项奖励
3 条消息(共 7 条)
3,315 次查看
I think you could use the parallel port in a similar fashion with LED's.  But I don't know how to program it in Labview.  I've never tried communicating through a parallel port before where I would have to worry about its port settings.
0 项奖励
4 条消息(共 7 条)
3,310 次查看
> &nbsp;
> Regards.
Controlling the parallel port in Labview is easy but if I remember
right you need to make the port look like a printer by a simple
connection between two pins.
0 项奖励
5 条消息(共 7 条)
3,295 次查看
Thanks. I'm a new LabVIEW user and I  don't know how to use the parallel port as a printer. Might you tell me about? Do you remember which are these two pins?
0 项奖励
6 条消息(共 7 条)
3,273 次查看
Please reconcider using the paralel port.
One small slip in connceting your wires can fry your computers mother board. 生气表情
Ben
7 条消息(共 7 条)
3,266 次查看
