08-07-2007 01:56 PM
08-08-2007 09:37 PM - edited 08-08-2007 09:37 PM
Hello Villalro,
Are you using the DAQmx Create Virtual Channel.vi in your application? Below is a great example of how to measure three different types of thermocouples all in the same task. If you are still not able to create the task correctly, you might try building it in a DAQ Assistant. Once you are able to create the task correctly in the DAQ Assistant, you can convert it into DAQmx code. Right-click on the DAQ Assistant and then select Generate NI-DAQmx Code.
Message Edited by Robert F on 08-08-2007 09:40 PM
08-09-2007 12:55 AM
Villarlo,
Did u mean SCXI 1112 modules??
Which DAQ card are you using??
Does it support DAQmx??
08-09-2007 08:02 AM
