Tree population from file
Hi everyone,
I'm writing the UI code of a test system and I'm archieving the project and test data in the files that's already been created at the start of the program.
So I have a pattern such that folders with project names and test files inside them with corresponding order.
e.g.
Project1
          Test1
           Test2
Project2
          Test1
          Test2
The problem is I cannot find a way to populate a tree with that order programmatically, by taking the names of the folders, files etc...
Thank you
(3,726 Views)
Accepted by Ademirel
-If the folders are already exisiting and if you just need to populate and display, check this example:
Displaying Directory Hierarchy with the Tree Control
-If you have to create folders then there's an example Tree control to file directory
uday
(3,713 Views)
Thank you so much, it was really helpful
(3,708 Views)
