Example Code
Tree Control To File Directory Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to generate a file directory with the tree structure.
Description
The recursive VI creates a folder for the each item at the current level in the tree, searches each item for children, and calls itself if any children are found. It returns when there are no more items at that level.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Choose a base path for the directory.
  2. Configure child folders in a tree control below. You can control the child folder depth by using drag and drop at the folder name.
  3. The folder configuration option can be found by right-clicking the tree structure control.
  4. Run the VI.
VI Snippet
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
