MAX-Software not listed
Pls find attachment.
The softwares are not listed/displayed.
Help pls.
(4,153 Views)
I believe that you got error 7411,
These error message occur because the MAX version being used (4.2.1 or earlier) to communicate with the Real-Time target is incompatible with the VxWorks version that is installed with LabVIEW Real-Time 8.5. To fix this issue you must upgrade your MAX version to version 4.3 (Driver CD August 2007) or later to access/install/remove software for cRIO-901x targets running LabVIEW Real-Time 8.5.
- If that's the case upgrade MAX.
Ref: http://digital.ni.com/public.nsf/allkb/1584D952E54ABB59862572F7006F3438
uday
(4,135 Views)
I already tried to install max updated version but i could not find the link.Also my LV is in English whereas MAX is in german.
Any leads on this???
(4,117 Views)
What is your version of MAX, LabVIEW Real-Time?
-Did you try downgrade the software on the cRIO so that it is compatible with your version of MAX?
uday
(4,111 Views)
I will check the MAX version when i go to the lab.
For the SW upgrade/downgrade,the SW in the Remote Systems must enlist the available SWs,that is exactly not happening so posted here.Also except the CRIO,the other HW modules are not enlisted.
(4,107 Views)
Installed MAX 4.6.2 even then the SW in the CRIO is not listed.Both pics attached.
Pls help.
(4,085 Views)
