Transfer 1-d array using DMA FIFO from FPGA
I am trying to transfer a 1-D array of two U32, using a U32 configured FIFO to the host,
but I get error due to connecting to different terminal types,
It looks very simple, I've found many samples around here with very similar treatment, but I can't see the problem?!
Message 1 of 8
(8,232 Views)
The data type of an FPGA FIFO can't be an array, it must be scalar. In your case it's a U32.
And you can only write one element to a FIFO per Write operation. So you'll have to write the data to the FIFO element by element.
Message 2 of 8
(8,217 Views)
But in this example:
https://decibel.ni.com/content/docs/DOC-6303
I think FIFO is passing an array, right?
Message 3 of 8
(8,213 Views)
Accepted by ecksor
There's a for loop indexing the array... So the write operation is element by element.
The read operation (on the host) can read several elements at a time (--> an array).
Message 4 of 8
(8,208 Views)
Message 5 of 8
(8,203 Views)
Thanks for your response.
But it leads to another question,
How can I transfer several channels in this situation on a Single-Cycle Timed Loop?
I am using Timed Loop because I need to read digital data at high speed up to 40MHz, and because of limits in number of DMAs I need to pass several channels by one FIFO.
Message 6 of 8
(8,185 Views)
It's quite simple: send one channel per iteration. If you need the sampling of all channels to be synchronous you'll have to store the values in a shift register to send it later.
In the screenshot you posted you could change the code like this (looks like you're using counter values from 1-32):
- when the counter reaches 32, write the data of ch1 to the FIFO and store the value of ch2 into a shift register
- when the counter is at value 1 write the value of ch2 (which was stored in the shift register) to the FIFO
- in all other cases just increase the counter
Message 7 of 8
(8,179 Views)
Thanks again, for your great help.
Message 8 of 8
(8,176 Views)
