Thermal image processing
Now you have a 2D array with all your pixel values. Use array index function to access each pixel value using the 2 indices of your image. You can build a VI for example that would plot in 2 waveform graphes the pixel values of one row and one column of your image corresponding to a cursor that you would manually move on the intensity graph.
Marc Dubois
Message 11 of 17
(1,606 Views)
I believe code similar to what I posted in this thread would allow grabbing the point under the mouse that could be scaled and displayed.
Ben
Message 12 of 17
(1,596 Views)
Here is an advanced version of what I mentioned above. It is pretty old code that I just cleaned-up a little bit but you should be able to use it, either by loading a comma-separated file of your own data or by copying the code into your own code.
The default data is a multimode CO2 laser beam. The cursors can be moved to plot on the waveform graph the laser beam profile between the two cursors.
Marc Dubois
Message 13 of 17
(1,580 Views)
Thanks, Marc Dubois
I need to find out the width of the region with high temperature that is my region of interest (ROI).
If I find out first and the last index of pixel with high temperature than i will get my result.
The picture is attached.
Message 14 of 17
(1,559 Views)
Thanks Ben
Actually, all process is carried out in a closed room because of high power laser. I cannot see the process during laser cladding because my system is inside that room. I have to store all the results.
So, I do not need a program which shows me value under the mouse.
Thanks again.
Message 15 of 17
(1,555 Views)
Why not use Particle measurements after you threshold the image?
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/particle_measurements/
uday
Message 16 of 17
(1,544 Views)
Thanks, everyone.
I have found an easy solution to measure the width of my region of intrust.
I am Just using ''Count and Measure Objects'' VI available in  ''NI Vision Development Module''
Message 17 of 17
(1,518 Views)
