Thermal image processing
I am using pyro-cam to find out the temperature of a laser cladding process. I am saving images of the real-time process. How can I draw a graph which shows the temperature of each pixel with pixel's index value?
My graph data is coming from 1D Array, that is wrong.
I am also sharing my Graph, and picture of laser cladding process.
By default, the black region in picture considered as a 650 degree.
Message 1 of 17
(6,197 Views)
VI also attached...
Message 2 of 17
(6,139 Views)
Connect the output of your reshape Array function to an Intensity graph. That will plot your data in a 2D graph. You have to use property nodes to change the color table if you don't like the default one.
Marc Dubois
Message 3 of 17
(6,123 Views)
I would say generally NI image display is much more convenient for working with images, than Intenstiy graph: faster, more convenient zoom, select regions, ROI, overlay tools, particle filter and analysis, other vision functions.
Intensity graph has a cursor and supposes more work with raw data.
Message 4 of 17
(6,106 Views)
Thanks for your reply.
I am already using NI image display. But my question is not how can I display my image.
I want to show and store the temperature of each pixel of an image with its index value.
Message 5 of 17
(6,071 Views)
Thanks for your reply MarcDub.
Intensity graph is not showing anything.
Pictures are attached.
Message 6 of 17
(6,063 Views)
Set the amplitude on Autoscale or manually set the min and max values to the same values than your waveform graph.
Marc Dubois
Message 7 of 17
(6,056 Views)
Thanks Marc Dubois
I tried both but no Such results.
Pics are attached.
Message 8 of 17
(6,051 Views)
For whatever reason, your X-axis has changed. Leave it as it was in the first picture (0 to 480) and you should see your image.
Marc Dubois
Message 9 of 17
(6,040 Views)
Thanks Marc Dubois
My real question was
''How can I draw a graph which shows the temperature of each pixel with pixel's index value?''
But from your help, I am getting the following result as shown in attached file.
Message 10 of 17
(6,028 Views)
