The pages of a TabControl have a "Colors" property - what does it do?
      I was hoping to use a (LV7.1) tabcontrol and make the pages different colors (to indicate a "state" associated with specific page) so I tried setting Foreground and Background to different colors - but nothing appears to change. Smiley Sad
What does the "Colors" Page-property do?
Thanks!  Smiley Happy
Message Edited by Dynamik on 03-20-2006 03:36 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
Message 1 of 12
(3,932 Views)
You probably have a dialog tab control...you cannot change the colors of any of the objects on the System palette.  Try dropping a tab control from the Containers palette, you should be able to change its colors.
-D
Message 2 of 12
(3,924 Views)
Hi Darren,
Thanks for quick reply! Smiley Happy
I (re) selected the TabControl from containers, still no (apparent) effect.
Message 3 of 12
(3,922 Views)
The color property for the page is only used if you check Allow Multiple Colors in the Advanced right-click menu (also a tab property).
___________________
Try to take over the world!
Message 4 of 12
(3,917 Views)
Thanks tst!
Changed TabControl property to AllowMultipleColors ran VI. page-color changed...
... and LabVIEW promptly crashed! Smiley Very Happy
You guys probably already know this, but page-captions can be changed at run-time too (IndependentLabel = True).
Thanks/Cheers
Message 5 of 12
(3,909 Views)
Yikes!
I think I reported a bug back in LV 6.1 that LV would crash if I changed the color of a tab that was not visable. If you conditionally set the color on only pages that are visable does it still crash?
Ben
Message 6 of 12
(3,898 Views)
Hi Ben,
Saw your post and re-created VI several times, tested color-change with tab-selected/un-selected, tried to follow same steps - unable to reproduce crash. Smiley Happy
Plan to incorporate tab-page-colors in test app. will follow-up (here) if problem recurs.
BTW, thanks for tip! - that work-around could [still] be very valuable.
Message 7 of 12
(3,887 Views)
"tab-selected/un-selected"
It was for hidden pages. You can right-click and hide the page. It shows up in the "visable" property of the page.
Ben
Message 8 of 12
(3,887 Views)
Yes it is still in LV 7.1.
This VI illustrates what you need to re-create this crash.
Make at least one tab hidden and set the "Crash?" boolean to true to crash.
If someone will confirm this on their machine, I'll post it the the Bug Thread.
Ben
Message Edited by Ben on 03-20-200605:41 PM
Message 9 of 12
(3,887 Views)
You're right - I misunderstood your post, and my app uses the "PageVis" attribute.  But crash occurred on Untitled VI with brand-new TabControl, though there were other VIs open - several with reference controls and maybe one reference-to-reference control.  I've noticed LabVIEW get a bit temperamental in this environment.
Message 10 of 12
(3,874 Views)
