Labview interaction with MATLAB
I'm working with Matlab script in labview.
i have both Matlab6.5 and Matlab7.0 on the PC.
i have changed the matscript.dll file as requested to work with Matlab6 or later.
i need to work with the Matlab7.0 but the Labview is going to the Labview 6.5 always.
how can i direct Labview to work with the Matlab7.0 (without uninstalling the 6.5)??
Idan Wexler
Analog Cells Team
Texas-Instruments -BC-IL
e-mail: idanw@ti.com
Tel: 972-9-970-6743
Fax: 972-9-970-6430
Mailing address: 8 Hasadnaot St. 3rd floor, Herzelia 46766, Israel
(3,279 Views)
Hi Idan,
perhaps this can help you:
Please make a backup of your registry before trying this!
- open regedit
- go to HKEY_CLASSES_ROOT\Matlab.Application\CLSID and look at the ID provided
- Cross reference that key to HKEY_CLASSES_ROOT\CLSID and see which executable is getting run
- Change the CLSID in the first path to reference MATLAB 7.0
- close regedit
 Andi
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(3,270 Views)
Thanks, Andi.
It's working.
Do you know if it's possible to specify Labview to work between Matlab 6.5 and 6.5.1. as they both have the same registery Id? (weird as it sound, i have Matlab 6.5.1, 6.5 and 7 on the same computer)
Idan.
(3,256 Views)
Sorry Idan,
at this point I can't help you. Perhaps the Matlab-Support can help you with the identical IDs.
 Andi
(3,242 Views)
